2.30.02 Unhandled exception with CPU
  • 2.30.02 Unhandled exception with CPU
    Just installed the newest vray for 2012 2.30.02. Works great in CUDA , but it's not working at all when I switch it to CPU. Any suggestions. Click image for larger version
    Is this on any scene, or just a particular one?
      Any scene where I imported Geometry. If I create a new scene and use max to model it's fine. I model mostly in sketchup.
        Then I'll need a scene for this; if you can send me one to vlado@chaosgroup.com it will be very helpful to fix the issue.
          I sent it. Thanks.
            Just checking to see if you have seen the file?
              This model was imported from revit not sketchup. Sorry about that.
