Vray Rt different bucket shades
  • Vray Rt different bucket shades
    Hi
    Can anyone shed some light.
    Just started testing Vray Rt, working great with 1 pc.
    When I add a second machine, the buckets are all different shades, see attached jpeg.
    Workstation is setup with a linear work flow with gamma 2.2
    The network is on auto-start, only using 1 slave pc.
    Any idea what would cause this.
    Its looks like the slave pc is using a different colour mapping?
    Thanks for help
    Derek
    Ok
    Think its because slave is not seeing the textures.
    Now just have to figure out how to direct RT to textures as RT doesnt seem to work the same as DR?
      Anyone have a tutorial to setup using UNC Paths?
        Umh did u mapped ur hard drive from slave on to ur workstation/server with assets/files/textures?
          Hi
          Yes I had shared the materials folder over network and added it to the slave 3DS Max Custom path, that has work for DR but not for RT, so was trying to setup using UNC path names, have had no luck, really wish it would be a simpler setup. Did see Vlado say they would be simplyfying process in future updates, will what and see.
            Hi Derek,
            Do you have RT render server set as service?
            Do you get any errors in the console window if it's started manually?
            Tashko Zashev | chaos.com
