RT Crashing with some materials
  • RT Crashing with some materials
    Hey there,
    Basically, I've got a scene that has been created with normal vray.
    I tried to render anim it with RT GPU and the first frame works fine, at the second one, it crashes.
    I tried to identify the problem, and it seems to be related with some materials. So now, I try to unhide object after object to see which one makes the problem.
    I was just wondering in the mean time if those error messages where any relevant for anyone :
ID:	877656Click image for larger version
    Is there any known materials that makes RT crashes? if so I can quickly see if there are here with zorb modifier script, and take them out.
    Thanks
    Stan
    3LP Team
    All right, it seems it was a blend material based on a dirt that was in a multi-material that caused the crash.
    Not sure why...
    Vlado, do you want that shader mlib to troubleshoot?
    Stan
    3LP Team
      Yes, please send it to vray@chaosgroup.com; I suppose it's the dirt map but it would good to check anyways.
