Vray RT problem with HDR map in Vray dome light texture map does not show
  • Vray RT problem with HDR map in Vray dome light texture map does not show
    Hi
    I have installed vray 2.40.04 on 3ds Max 2014 SP2. And when i use Vray RT on active shade, i put a Vray dome light in, (active shade works fine) then i add a vray hdr map in the material editor, and drag it over to the Texture slot on the vray dome light, the image goes black, ive pumped up the intensity of the light and material thinking maybe it was just dark, then i changed from a vray camera to a regular max camera and no change, has anyone got any ideas? Is it something im doing?
    thanks
    Rob
    Hello Rob,
    Thank you very much for you feedback.
    I've just run the same test with the same Vray and Max versions and I could confirm that VrayDomeLight works correctly with assigned VrayHDRITex.
    Please make sure that HDR-file is attached into VrayHDRITex and the correct mapping is set.
    What about production renderer - does it produce the same black-result ?
