thin objects render errors with GPU
  • thin objects render errors with GPU
    hello i want to render a thin object. its basically an outline extruded to .075. a foil.
    it is meshes in grid manner to apply deformation.
    rt gpu produces render/smoothing?-errors around the vertices of the planar part ( the top-plane).
    rt with cpu renders correct.
    andreplx
    Can you show me? Also, can you send us the scene to vray@chaosgroup.com so that we can try to figure out a way around it?
