Bump more defined in RT
  • Bump more defined in RT
    Why is bumpmaps more defined in rt than in regular production render?
    This also affects the glossiness so its hard to switch between these 2 and get the same result.
    Is it possible to post few render examples?
    What is your GI setup for the production renderer?
    Tashko Zashev | chaos.com
      I think my problem is related to normal maps, no support for it in the GPU?
        Generally normal maps should work fine on the GPU; if you have a scene where it doesn't it would be good to send it to us.
