V-Ray RT Preview Animation Not works.
Living in my VrayPhysicalCam, with low Exposure settings... Now with Lightmapping.
Spanish V-Ray 3.0 Licensed Instructor
Artefaktos 3D&FX School
@artefaktos3d -
Thanks Vlado, I go to try the new build now.Living in my VrayPhysicalCam, with low Exposure settings... Now with Lightmapping.
@artefaktos3d
Originally posted by E-Lahoz View PostThanks Vlado, I go to try the new build now.Living in my VrayPhysicalCam, with low Exposure settings... Now with Lightmapping.
@artefaktos3d
It's fine in my tests, can you send me your scene ? peter.matanov@chaosgroup.comIf it was that easy, it would have already been done
Peter Matanov
Chaos
Scene sended.Living in my VrayPhysicalCam, with low Exposure settings... Now with Lightmapping.
@artefaktos3d
No Sprawl, for now I can't solve it.Living in my VrayPhysicalCam, with low Exposure settings... Now with Lightmapping.
@artefaktos3d
E-Lahoz the scene you sent me is working flawlessly, Sprawl I'm waiting for yours at peter.matanov@chaosgroup.comIf it was that easy, it would have already been done
Peter Matanov
Chaos
Same problem now. I'm testing RT Animation Preview in Production Render, but only makes me frame 0... and when I close and open the RT animation Preview Settings window, not works. I need to restart 3DS Max to try another time... and not works...
* 3DS Max 2015 SP3
* V-Ray EDU 3.10.03Living in my VrayPhysicalCam, with low Exposure settings... Now with Lightmapping.
@artefaktos3d
Hi again,
I have to do a preview anim with RT but again the same problem: render frame 0 than block on frame 1. I try to restart max and try with an empty scene and do the same so it's not a scene problem but something else.
The strange thing is that 2 days ago it worked, but i don't change anything on my workstation
The problem is both CPU or CUDA mode
3DS Max 2015 sp3, vray 3.10.03, quadro k5200, dual monitor (don't know if this could be a problem)
I don't know what to do, but help me please, because i need to do this preview animation
Thank you
Sprawl
You have two other options.
First one is to simply set V-Ray RT as a production renderer and just render as normal animation (make sure you select CUDA as the engine if you want GPU render).
The second option is to render with V-Ray Standalone. Right-click in the viewport that you want to render, and select ".vrscene exporter", enter a file name in the first field, something like "c:\temp\test.vrscene", turn on "export animation" and select the wanted frame range, then click "Export" (not "Export and render"). After that, open a command prompt (Start menu > Run... > type "cmd" without the quotes), and on the command prompt, type the following (this is just one line):Code:"c:\Program Files\Chaos Group\V-Ray\RT for 3ds Max 2015 for x64\bin\vray.exe" -scenefile=c:\temp\test.vrscene -imgfile=d:\temp\test_out.png -rtengine=5 -rtsamplelevel=100
VladoI only act like I know everything, Rogers.
Hi Vlado,
I see a little problem: vray render the anim, but overwrite the same image file, how could i tell him to generate image frames ?
Thank you
Sprawl
Edit: Ok I found the standalone help file. I added this command: "-noFrameNumbers=1" and now worksLast edited by Sprawl; 29-04-2015, 09:43 AM.
