Vray camera is broken when rendering through Backburner (VrayRT)
  • Vray camera is broken when rendering through Backburner (VrayRT)
    I'm using VrayRT 3.00.07 and Max 2015 sp2.
    When you render in Max with Vray-Camera, everything is fine.
Name:	rendered in max.jpg
    When you submit the scene to Backburner, the vrayCamera renders as zoomed in or out. And there's no way I can match them.
Name:	rendered with backburner.jpg
    If I use the normal Max Camera, it renders fine both in Max and Backburner.
    But the Max Camera is useless with Vray as there are no exposure controls.
    This is definitely a bug.
    In the past 3 weeks I have discovered several bugs... so if I am to buy Vray(i'm on the trial version now), do i have to buy it with those bugs ? (rethorical question)
    Thank you.
    Regards,
    Peter Istrate.
    CGI studio: www.moxels.com
    i7-4930K @ 3,4GHz watercooled
    Asus Rampage V Extreme Black Edition Intel X79
    64 GB DDR3 Corsair Vengeance Jet Black 1866 MHz Quad Channel
    8 * GTX Titan X
    960GB SSD Crucial M500 SATA-3
    nVidia drivers: always latest
    Windows 10 up to date
    Originally posted by peteristrate View Post
    [ATTACH=CONFIG]20622[/ATTACH]
    [ATTACH=CONFIG]20621[/ATTACH]
    Thank you.
    Regards,
    Peter Istrate.
    Doest standard max camera works fine?
      Hi Dariusz,
      Yes, the standard Max camera works fine. I've stated that already, read again
      8 * GTX Titan X
        Aw sory, blindness has me... Humh that's strange in this case
          Hi Peter,
          Yes, there is a bug. The case is already logged to our system and we will fix it.
Name:	2014-08-25 11_31_12.jpg
          Thank you for sharing your experience.
          Tashko Zashev | chaos.com
            Cool.
            For now I have worked it around with Batch rendering because I have several cameras in one scene(out of several other scenes), but when you have multiple scenes, Backburner is needed.
            Looking forward to see it fixed in the next build.
            Thanks.
            8 * GTX Titan X
              Thanks for your update Peter.
              Our developers are working on the fix right now, so we will notify you on any update.
                I have also noticed that if I render through Batch renderer(not Backburner) and I try to save the renders as .hdr, it saves the image as black.
                If I save the image manually, using the VFB save button, it saves ok, but if it's saved through Batch rendering, it saves black.
                Regards,
                Peter Istrate.
                8 * GTX Titan X
                  Is that only for HDR files? What about OpenEXR?
                    The OpenEXR is fine.
                    The .hdr is not.
                    I haven't tried other file formats. I think you can replicate this with a very simple scene - just try to render and save with Batch rendering.
                    Regards,
                    Peter Istrate.
                    8 * GTX Titan X
                      Hi Peter,
                      I can replicate this issue only if I use the native 3DS max save option.
                      Saving from Render settings > V-Ray frame buffer > Separate render channels to HDR file works fine in my test. Could you use this as a workaround?
                        When you save to HDR, 3ds Max puts up a dialog box asking if you want to use non-clamped (realpixel) color channel, or use standard RGB channel. Which option did you select? The first one will not work.
                        The RT engine also has an option to generate a floating-point image buffer, which you might need to enable.
                          @Vlado:
                          The floating point buffer option("Use 32 bit frame buffer"?) for the frame buffer is checked.
                          For HDR, i use the non-clamped (realpixel) color channel because I need the whole 32 bit range of the image to alter it in compositing. The standard RGB channel is just an 8bit image if i'm not mistaken.
                          @Tashko:
                          If I use the save "separate render channels" then all my batched renders will have the same path that was set in "separate render channels".
                          Saving from Render settings > V-Ray frame buffer > Separate render channels to HDR file works fine, indeed but then I can't have different multiple saving paths as Batch rendering allows you to so that's why i need to save through Batch rendering(which uses the standard max saving option).
                          I could create a different "Scene State" for each of my renders so in that case, each camera will have it's own scene state with its own render settings(including "Separate render channels") and then I can assign the corresponding render state in Batch rendering, but this is not feasible at all.
                          8 * GTX Titan X
                            The realpixel channel option will not work. Use the other one - it works just fine and will produce proper HDR data.
                            • #15
                              I was rendering today with Batch rendering as a workaround for Backburner and I have noticed the cropping(or zoom factor) occurs with Batch rendering as well this time. I had 2 batch render entries(2 cameras): the first one rendered correctly, the second one rendered cropped/zoomed.
                              But it worked fine for other scenes before.
                              That is very strange.
                              8 * GTX Titan X
