Gtx 970
  • #16
    All scenes crash and I have tried CPU, and both the GPU options. The dump file is over two gigs, so I can't sent it.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      Also, in the nightly, I don't see MAX 2015. I installed a nightly for yesterday, which I thought was 2015, but I don't see it now.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
      • #18
        You have to see what are the errors in the VRay console. This console is running as a separate vray.exe process every time you start the RT engine.
        Also, are you sure you have installed the correct version, it should be named something like /vray_adv_30008_max2015_x64_25280.rar
        V-Ray fan.
        Looking busy around GPUs ...
        RTX ON
        • #19
          Well, I am still on 2.0, so I am seeing vray_adv_25501...
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #20
            Okay, is it named vray_adv_25001_max2015_x64_25111.rar ?
            If so, check the installed version and the console output for errors ... It will help us to track down the issue.
            I am pretty sure we've added the Maxwell support a while ago. In the worst case, we still have not (I am not in the office right now and I can't check at the moment. If it is so, we will fix that asap).
            V-Ray fan.
            RTX ON
            • #21
              I am not seeing that one, I am seeing vray_adv_25501_max2015_x64_25330
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #22
                Okay, it's not a nightly; it's a stable release. i'll try that one. However, wouldn't the nightly be newer and include the fix? Anyway, I guess I'll find out. Thanks for the help.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  You should look in https://nightlies.chaosgroup.com/.
                  V-Ray fan.
                  RTX ON
                  • #24
                    I did, but the number mentioned is in the stable folder; I tried the latest nightly, but it failed.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #25
                      The support for Nvidia Maxwell has been added since two months in the 2.x nightly builds.
                      Did you try with one very simple scene ? Does it crashes again ? Maybe the crash is related to this specific scene.
                      Tashko Zashev | chaos.com
                      • #26
                        I had it as a service. I removed it as a service and launched it manually; it stopped crashing. I'll test it out this way and report back.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          I've verified that it is working fine both in the nightly and in the stable.
                          You can't run any GPU application as a service - this limitation is not caused by V-Ray, it is just how GPUs and Windows work.
                          If you have any troubles, it would be best to provide the log from the V-Ray console itself (thus we can tell what is wrong easily).
                          Best,
                          Blago.
                          V-Ray fan.
                          RTX ON
                          • #28
                            you got it, thanks!
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #29
                              it's differently when I rotate my HDRI. The second I rotate, RT crashes. I have to rotate, crash, render, rotate, crash, render...
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #30
                                Can you try with the 3.1 release that's on the website?
