xref objects renders black in RT GPU
  • xref objects renders black in RT GPU
    Are you aware of this problem? Most xref objects render completely black. Not sure if this is a multisub mat problem. CPU mode works fine though.
    This didn't work prior to Vray 3.10.03 either. At least for me.
    www.nikand.com
    3D Freelance
    Hmm, it makes no sense for this to work in the CPU mode but not in the GPU. Can you attach a scene with this issue or send to support@chaosgroup.com ?
      Yes, but for me it doesn't work, hmm...
ID:	855232Click image for larger version
ID:	855233Click image for larger version
ID:	855234Click image for larger version
      I will send you the teapot scene
      /Nikolaj
      www.nikand.com
      3D Freelance
        Oh, you mean the material doesn't render... that's slightly different. Thanks for the scene, will check it out.
          Thnak you for sending us the scene.
          We reproduced the issue and add it in our bug tracking system. We will let you know as soon as we have any update.
            The issue is now fixed. The fix is available in the latest Stable builds and it will be part of in the next SP as well.
