Hi, I'm getting some strange errors with RT.
I can render with vray normally. (Just a test scene with a sphere, so nothing complicated). But when I try and switch the viewport renderer to RT I get this error.
// Warning: line 1: Render host ... (127.0.0.1:20207) is not responding //
Also I seem to be getting a new error when I try to open the render settings for the first time after starting Maya.
# Error: line 1: MelError: file C:\Program Files\Autodesk\Maya2014\Python\lib\site-packages\pymel\core\language.py line 846: Error during execution of MEL script: file: C:/Program Files/Autodesk/Maya2014/scripts/others/createMayaSoftwareCommonGlobalsTab.mel line 48: setParent: Object 'commonTabColumn' not found.
After I see this error the "Vray Common" panel is blank, until I switch to another tab in Render settings such as "GI" then when I switch back to "Vray Common" the panel controls are back.
Are these related maybe?
Thanks in advance
Thanks in advance
