Hi!
I've problem rendering a bitmap sequence in the opacity slot with a standard Vray material with Vray RT GPU. It animates fine in the viewport when previewing the opacity map. The diffuse channel render fine and keeps rendering the next bitmap in the sequence. The opacity slot bitmap just disappears after the first frame. I'am later trying to render a scene with a lot of walking people in it. I'am attaching a simple render to describe the problem. First frame render fine and efter that the opacity bitmap doesn't have any effect.
Hopefully I'am not doing anything wrong this time
Thank you for a great render and an awesome forum, like to read here a lot!
