Memory adding up at each rendered frame and craching.
  • Memory adding up at each rendered frame and craching.
    I'm trying to render a animation with RT GPU.
    After sending the job to BB, the render starts and everything work great.
    Once the frame in rendered it saves the frame out and, for some reasons, the memory goes up before tackling the next frame.
    My scene takes about 2Gb to render the first frame but after 4-5 frames, it's hitting my GPU ram limit (4Gb) and it crashes.
    Any thoughts?
    Vlado, I send you a email with the link to the scene if you have time to have a look.
    Cheers
    Stan
    3LP Team
    It would be a good idea to send the file also to support@chaosgroup.com.
    Let us know what is the exact version of V-Ray/3D Platform and OS.
    What is the GPU device and its drivers version?
      just forward you the email with the scene.
      Here are the details :
      Vray 3.15.01 (vray_adv_31501_max2014_x64_25662)
      Max 2014 SP5
      Win 7 64 Pro SP1
      3x GTX 970 - Driver 344.16
      Stan
      3LP Team
        By the way, if this helps, this is the message I got :
        Stan
        3LP Team
          Thanks, looking into it.
