V-Ray RT CUDA Erorrs
  • V-Ray RT CUDA Erorrs
    recently I am experiencing some errors with RT. It all started suddenly and now most of my scenes (which were working a few days ago) yield errors leading to vray.exe crashes.
    Errors:
    error: ./src/ocl_tracedevice.cpp(2046) : CUDA error 716
    sometimes there is also CUDA error 999.
    Geforce TITAN X on driver ver.: 352.86. V-Ray for Maya 2016, RT ver. 3.25.01
    Thanks in advance!
    Have you changed something in your system(hardware/software) recently?
    Does the crash occur on every scene? Does it render with empty scene ?
    Does it render when started from standalone (vray -sceneFile="/path/to/vrscene" -rtengine=5 -numthreads=1 -verbose=4)?
      There is a problem with the latest Nvidia driver version - 352.86 and our RT / Cuda engine stops working with an error 700 or 999.
      You can set Environment variable VRAY_CUDA_DISABLE_PTX_OPTIMIZATION = 1 to get it working again or revert back to an older driver version.
      Tashko Zashev | chaos.com
        Okay, it seems that the newest nVidia driver is causing that.
        You have to downgrade to something older - like 350.12 (or you can just set the env var VRAY_CUDA_DISABLE_PTX_OPTIMIZATION=1 .. This would made the rendering about 5-15% slower though).
        We've reported that and we'll work to find a way to make that work ...
        edit : apperantly I was a bit too late
        V-Ray fan.
        Looking busy around GPUs ...
        RTX ON
          Yes, now that you say it I remember updating the drivers a few days ago so I guess it is the driver's fault. Should I go with the env variable untill the next V-Ray build shows up? Or untill the next Nvidia driver is released?
            You can either go with the env (remember to restart Maya/Max/Vray) and wait for the next driver version, or you can install the previous nVidia driver (350.12).
            V-Ray fan.
            RTX ON
              All right, thank you very much!
