Anisotropy not working on GPU
  • Anisotropy not working on GPU
    Hi
    Anisotropy on GPU is a new feature of Vray 3.2. Somehow this doesn't work for me. I have duplicated your material settings from the official 3.2 video
    https://www.youtube.com/watch?v=d_fuhYzxZNc.
    Works fine on cpu though. Is it a known bug or am I missing something?
    www.nikand.com
    3D Freelance
    It works fine over here. If you have a scene where it doesn't, can you send to support@chaosgroup.com so that the support guys can look into it?
      hmm tried it on different scenes with no luck with Blinn material. I will send a simpified scene to you.
      www.nikand.com
      3D Freelance
        Found the bug. Anisotrophy doesn't work when its part of a multisub material
        www.nikand.com
        3D Freelance
          Oh, good catch - will fix it.
            Just to add up - it's not working only if using "Map Channel" mode for the anisotropy, local axis mode is fine.
            Peter Matanov
            Chaos
              Nice..that worked Peter.
              Vlado there is also a strange line from the Gradient Ramp with GPU. Compare cpu and gpu versions from this thread.
              http://forums.chaosgroup.com/showthr...368#post667368
              www.nikand.com
              3D Freelance
