VrayRT 3.304 - unusable now:(
  • VrayRT 3.304 - unusable now:(
    I get one of the following errors on basically 9 out of 10 renders. It's at the point where RT is unusable.
    Scenes are pretty basic. Just tested 5 scenes - no one works.
    Sometimes I'm lucky to get 1 frame rendered then crash.
    I also get a black screen of death quite often if in-process RT engine is on.
    Error:./src/ocl_tracedevice.cpp(2063):CUDAerror700
    Error:./src/ocl_tracedevice.cpp(2063):CUDAerror719;exception occurred on the device while executing a kernel
    Error:./src/ocl_tracedevice.cpp(2187):CUDAerror719;exception occurred on the device while executing a kernel
    Driver is 361.75
    OpenCL is a little more stable but slow compared to cuda.
    Anyone else experiencing this?
    www.nikand.com
    3D Freelance
    This is not known issue. Sharing the scene will definitely help to find what is going on.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      Those are five out of five scenes. And they are not handpicked. Unfortunately I cannot get any scene to render consistently after 3.304 update and geforce Driver 361.75.
      Would you recommend a specific driver?
      I will try to send you some scenes. But basically its every scene I have tried.
      www.nikand.com
      3D Freelance
        Another simple test. Just a floor with a texture and white plane as wall and Domelight hdri.
        Not working.
        Will send the scene.
        www.nikand.com
        3D Freelance
          In addition to the scene, can you also tell us what graphics card you are using?
            gtx 980ti, there is some info in the logfile in the first picture
            www.nikand.com
            3D Freelance
