We're having issues rendering image sequences using Vray RT (3.5, yesterdays Nightly build) for max 2016. It is failing on random frames: we have monitored temps, ram usage etc and all is fine.
Looking at the log files after each error the last action each time is "clearing color mapper" and the vray message window shows: [VrayRTMax: renderThreadProc] Exeption occured in rendering thread
System info:
- Nvidia driver - 378.66, cleaned old drivers first using DDU & deselected all other options at install
- Plugins: railclone, forestpack, multitexture, Animators Tooolkit (ATK)
- 5 x titan x (maxwell) - max load temps recorded at 48 degrees & memory usage peaks at 11881mb (with monitor) between frames and avg 8879mb (error thrown mid frame on last test)
- X99 E-WS, 5960X, 64 GB DDR4 ram (memtest fine) - all drivers up to date
- Windows 8.1 pro x64
Any ideas on what we can do to quickly fix the issue, we're pressed to get this job rendered asap.
Cheers
System info:
Cheers
