[RT CUDA] Falloff map acts strange if set to "Soft Light" mode in a Composite map
  • [RT CUDA] Falloff map acts strange if set to "Soft Light" mode in a Composite map
    I've noticed that in RT CUDA I get very different result from RT CPU and Adv if I use a falloff map with "Soft Light" blending mode in a Composite map. All other blending modes render the same with any engine (RT CPU, RT CUDA, Adv). See screenshot below.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    3ds Max 2023.2.2 + Vray 7
    AMD Ryzen 9 9950X 16-core
    64GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 565.90
    Yep, you are right - there is a problem with this setup. Will log it right away, thanks!
    Peter Matanov
    Chaos
      Should be ok for the next version (it's already fixed in the nightlies).
      Peter Matanov
      Chaos
        Thanks!
        Aleksandar Mitov
        64GB DDR5
          I confirm that this is fixed now in Vray 3.6! Thank you!
          Aleksandar Mitov
          64GB DDR5
