I can't make the denoiser work with RT. Is it supported when rendering with GPU? All render elements get generated during rendering and I can see them in VFB except for "effectsResult" where the denoised image usually is found in Adv. Manually clicking on Update in the denoiser element didn't work either. I'm using the nightly by the way, check version in signature.
Denoiser not working with RT?
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14Tags: None
No, not using DR. :/Aleksandar Mitov
96GB DDR5
Today after installing a GTX 1080 ti the issue went away. Maybe the GTX 980 didn't have enough power or memory to compute it? Shouldn't it fall back to CPU denoising in such cases though?Aleksandar Mitov
96GB DDR5
I have the same problem with denoise render elements separately. Single pass on RGB only works finewww.nikand.com
3D Freelance
