Object not visible in render with CUDA but visible with Adv and RT CPU
  • Object not visible in render with CUDA but visible with Adv and RT CPU
    There's an object (a wall) in my scene that is both renderable and visible to camera but RT CUDA doesn't render it while Adv and RT CPU render it fine. Why would that happen? Please check the screenshots below:
    Click image for larger version  Name:	CUDA_missing_object.jpg Views:	1 Size:	125.7 KB ID:	953088
    Click image for larger version  Name:	invisible_to_camera.jpg Views:	1 Size:	150.7 KB ID:	953090
    Click image for larger version  Name:	camera.png Views:	2 Size:	12.1 KB ID:	953092
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    You know the procedure
    Peter Matanov
    Chaos
      You've got mail.
      Aleksandar Mitov
      96GB DDR5
        An update to the issue. I just received an email reply from support. Turns out there's a bug that makes objects inherit the visibility properties of other objects with the same material if that material is Multi/Sub-Object. A workaround in this particular case is to avoid using Multi/Sub-Object material.
        Aleksandar Mitov
        96GB DDR5
