displacement in multimat RT gpu problem
  • displacement in multimat RT gpu problem
    Hi
    Adding a displacement map in one of the multimats assigns displacement to all materials in the multimat.
    Regards Nikolaj
    www.nikand.com
    3D Freelance
    Are you using the Max Multi/Sub material in this setup ?
    I believe this is a known issue which we have to fix and it happens with RT CPU engine as well.
    Tashko Zashev | chaos.com
      Yes it's the max Multi/sub...it's been logged then, I guess the workaround right now is detaching the part that need displacement and assigning a seperate vray material.
      www.nikand.com
      3D Freelance
