Inaccurate results with Composite map compared to Adv?
  • Inaccurate results with Composite map compared to Adv?
    I've got a material setup that doesn't render the same with RT and Adv. It's like RT doesn't see the alpha in the PNG texture and doesn't use it in the mask of the Composite map. I've checked the used maps and materials and they are all supported according to the help docs. You can download the stripped down scene here (link expires in 7 days): https://we.tl/Z0dT3Rblor
    Click image for larger version  Name:	image_38040.jpg Views:	1 Size:	78.2 KB ID:	963890
    Click image for larger version  Name:	image_38039.jpg Views:	1 Size:	136.5 KB ID:	963889
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Is this thread visible? I can't find it in the forum. The only way I can access it is to check my recent posts.
    PS: Ok, I can see it now after I posted this message. Strange.
    Aleksandar Mitov
    96GB DDR5
      I would report this issue to our system. As a workaround in this particular scene you could try swiching the "Alpha Source" of your "mask' to Image Alpha.
      Nikolay Kusht | chaos.com
      Team Lead, 3D Support | contact us
        Thanks for the suggestion, Nikolay.
        Aleksandar Mitov
        96GB DDR5
