VrayLightMtl error when in multi/sub object Material
  • VrayLightMtl error when in multi/sub object Material
    Hi
    Put a Vray VrayLightMtl in a multi/sub object Mat and tick direct illumination on and there is no light.
    If direct illumination is off it works.
    Problem happen both in gpu/cpu mode
    /Nikolaj
    www.nikand.com
    3D Freelance
    Hi Nikolaj,
    What version are you using? We had a problem with nested light materials with direct illumination ON in 3.60.01 but it was fixed in 3.60.02. Anyway VRayLightMtl in Multi-Sub mtl with direct illumination ON is not supposed to work (it will act as it's OFF).
    Peter Matanov
    Chaos
      Hi Peter, my bad I am on 3.60.01. Will update thanx
      www.nikand.com
      3D Freelance
