Howdy all, most likely a basic question but my standard VFB render looks fine while the RT FB renders blown out. This happens in RT with both CPU as well as hybrid CPU/GPU. Of course would like to have renders appear the same in both FBs. Thanks
Difference between RT and Standard VFB
Yes, it's kind of annoying. This is because when you switch between RT and Adv (or vice versa), all render settings, including the VFB corrections, get reset. What I do to counter this is to save my image in the History panel before I switch to RT or Adv. Then when I start rendering I just right click the saved image in the history panel and select Load color corrections.Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
