Vray lightmat problem
  • Vray lightmat problem
    Hi the opacity slot in vray light material is not working with cuda.
    www.nikand.com
    3D Freelance
    Take a look here - https://forums.chaosgroup.com/forum/...alpha-sequence
    Peter Matanov
    Chaos
      Thanx I put the vray light mat and a transparent vray mat in a blend mat instead.
      I thougt the self illumination slot did not give the same result as vray light mat?
      www.nikand.com
      3D Freelance
        That is not a very good idea if not necessary. Blend materials are heavier to render and can increase render times.
        If you don't need the fancy options in the VRayLightMtl, it should be relatively the same.
        Peter Matanov
        Chaos
          Im using the displacement. I'll try the fasterr solution then...
          www.nikand.com
          3D Freelance
