RT GPU Bump map is broken
  • RT GPU Bump map is broken
    I often struggle with bumpmaps in rt gpu, especielly with refraction envolved.
    Here I use a noise map to create som surface bumps in a window.
    The GPU render however is very different from CPU and vray adv.
    Noise map uses UVW mapping. Baking the noisemap doesn't help either.
    What i don't understand is that bumpmaps often work great and sometimes they don't it seems.
    www.nikand.com
    3D Freelance
    Without refraction on and same settings. Looks very flat on gpu
    www.nikand.com
    3D Freelance
      Bump map works differently compared to CPU and we don't have plans to unify those 1:1 (V-Ray GPU is a different engine, after all).
      With that being said, there could be a bug. Can you share a sample scene that we can check?
      Best,
      Blago.
      V-Ray fan.
      Looking busy around GPUs ...
      RTX ON
        Fair enough I will make a sample scene. Bump does work great in many instances though. But with noise maps it seems hard get a desired look.
        The above reflection looks like a fractal map is used with blurry reflections. But material it 100% glossy with a standard noisemap at 4%
        www.nikand.com
        3D Freelance
