shadowcatcher gpu problem
  • shadowcatcher gpu problem
    simpel scene - a plane with shadowcatcher, chamferbox, vray planelight, hdri.
    Rt gpu on the right.
    Works fine if I remove shadowcatcher.
    Will send file
    www.nikand.com
    3D Freelance
    Could you please attach the file?
      sorry had a busy schedule...
      I have send it to support
      www.nikand.com
      3D Freelance
        Thank you for sharing the scene. The issue is logged for investigation. It's caused by the LC, if you disable Use for glossy rays or Store direct light option it will fix it.
        I'll let you know when we have any update.
          Thanks for the quick solution
          www.nikand.com
          3D Freelance
            Hi, is shadowcatcher working properly in official vray next release? Shadows affect alpha is not working in beta 3
            www.nikand.com
            3D Freelance
              There are no additional fixes for the shadow catcher in the official release compared to beta 3.
              We have in the todo list to improve it.
              Bets,
              Blago.
              V-Ray fan.
              Looking busy around GPUs ...
              RTX ON
                Solved: Disabling "use for glossy rays" solves the problem. Also using Brute force as secondary engine solves the issue
                I was running into similar differences. In my case it was when using the Standalone for rendering, while within MODO it worked as expected
                Volker Troy
                www.pixelwerk.at
                +43 (0) 664 / 3 820 810
                Radetzkystrasse 102 a
                A-6845 Hohenems
                Austria
                  When you render inside Modo, the GPU renderer is in "interactive" mode, so the light cache is not used.
                  I guess this is the reason the "inside Modo" render is working correctly.
                  Greetings,
                  Vladimir Nedev
                    Cpu and gpu differs a lot with shadowcatcher.
                    here is a simple scene. A box, plane(with shadowcatcher), 1 vray light and green background.
                    Green color is not the same and alpha on Gpu is all white.
                    www.nikand.com
                    3D Freelance
                      Yes, they use completely different algorithms. The white alpha on the GPU is strange though. Can you post that scene, even though it is very simple? The alpha looks fine in my simple tests.
