Can no longer render background self illumination plates.
  • Can no longer render background self illumination plates.
    I feel like I am taking crazy pills.
    So, I'm starting a new interior scene in Max 2018 Vray RT (latest version of both) and I realise the background plate I almost always use (from a Evermotion scene) is rendering as grey.
    But I knew it worked in my old scene - so I go back to the old scene (attached images) - in both 2018 and 2015 (the scene it was created in) - and sure enough, although the scene was orignally rendering fine, it seems like Vray has broken, because the background is rendering flat grey now.
    It's simply a cylinder with a self illumination value of 6.
    You can see the old render, rendered correctly, and the quick grab I did after starting it again with what is a later version of Vray.
    What's happening??
    http://www.jd3d.co.uk - Vray Mentor
    Hey JD,
    did you set the mapping type to standard? I had something similar with a sky dome I use pretty often.
    Best Regards
    Olaf
    Olaf Bendfeldt
    3D-Artist
    dimension3+
      Which mapping type? This is just a self illuminated material on a cylinder outside the room, not a sky dome with hdri
        Could you share the scene here or with our support ? Just the cylinder with the self illuminated material and some simple geometry for the room should be enough.
        Also could you write exactly which version of V-Ray are you using now and in which the backplate worked as you expected ?
        Yavor
        Yavor Rubenov
        V-Ray for 3ds Max developer
          My sky dome was also just plain geometry but with a VrayHDRI Map mapping type spherical. And this is not rendering with GPU only 3ds max standard.
          Olaf
          Olaf Bendfeldt
          3D-Artist
          dimension3+
            Here is the file and image background
            https://www.dropbox.com/s/cczhhqgwwh...issue.zip?dl=0
            Please note that during the lightcache phase you can see the image through the windows, but once the rendering phase begins the image is grey.
              I was curios, tried you scene and had the same bug. (max 2018 + vray rt 3.60.03). But it's gone when turning off the direct illumination checkbox in the vraylightmtl. Or when using a vraymtl and put the map in the self illum slot with gi on is working here. Seems like a bug.
              Olaf
              Olaf Bendfeldt
              3D-Artist
              dimension3+
                It's not a bug. It's just that now the Indirect Illumination toggle is working in GPU and it turns the geometry into a mesh light but mesh lights in GPU don't support texturing. Just turn the option off and you should be fine (it was always off in GPU before).
                Peter Matanov
                Chaos
                  I tend to think of things that don't work properly between ADV and RT as bugs, especially when I am taking assets from one scene to another. Is there any way this can be flagged or adjusted by VRAT RT to avoid this kind of confusion?
                    Can firm - it does work!
