Vray RT freezes / crashes after trying to render animation on 3DSMax frame buffer
  • Vray RT freezes / crashes after trying to render animation on 3DSMax frame buffer
    Hi all,
    Trying to render an animation with Vray VFB it works fine and saves rgb .tga sequence, switched from to 3DSMax FB in order to get some passes saved, Max renders the first frame just fine and then it freezes/crashes after... any idea what might be causing this? Using Vray 3.6.04 "RT"
    <Edit> figured how to do all throgh VrayFB, Max still freezes though. Please delete.
    Hello,
    I tried to reproduce the crash with the Max frame buffer but couldn't on a simple test scene. Do you get the freezes only on that specific scene or it happens on any scene ?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      It has happened in two different scenes with RT animation rendering, I'm on Windows 7, max 2017, Thx
        Could you send one such scene to support ?
        Yavor Rubenov
