Wish: "only in secondary"
  • Wish: "only in secondary"
    I'm using VfR and the material option "only in secondary" is one of my daily tools. But I found, it doesn't work in GPU mode. Is there a chance to get it in the near future? Is there an alternative?
    I need to render small spaces like air plane lavatories and used the option to look through hidden walls, which are visible at mirrors in the room. Also I use the option to hide emitters which I used the get glow effects around objects like back lit mirrors.
    -Micha
    I found a simple fully workaround. I post it here. The support of "only in secondary" seems to be possible.
    Hi, "only in secondary" isn't supported by GPU rendering. One of the most important options for my daily work. But I found a simple workaround since
