Render Mask Texture?
  • Render Mask Texture?
    It appears to me that GPU rendering doesn't support Render Mask Texture?
    Is this going to be added in future releases or it is simply not possible?
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    Hi, thanks for posting. It seems to work on my end:
    You have to set your mapping to "screen" - https://docs.chaos.com/display/VMAX/...ing-Parameters
    Vladimir Krastev | chaos.com
      Hi Vladimir,
      I don't have "Screen" as an option.
      I am using a bitmap for a Texture to mask part of the render out (I've done this before, a long time ago).
      I set Render Mask Type to Texture - I put a VRayBitMap texture in that slot and that texture has Mapping type set to 3DS Max Standard.
      When I use CPU rendering this works. When I switch the renderer to GPU it doesn't, hence why I believed it was a GPU issue.
      Please can you get back to me?
      Thanks.
      Jez
        Hi, you have to scroll down to coordinates and choose environ->screen
        I am sending you my scene (attached).
