Hello,
Today i'm playing with Hdri light Studio with VrayRT.
In my mind, the most usefull thing about RT at this time is to setup light materials and Map in very short time and intuitive way.
I really like the way i can modify a map in photoshop and just push the reload button of the Bitmap Map of 3DSMAX to see the changes in the active shade view.
So .. i want to use HDR light Studio to create my Hdri as a map for my VrayDome light.
It's so easy to setup this thing and creating my own Hdri with VrayRT !!
But something is missing ...
We can only use VrayHdri map , and this map haven't any reload button like Bitmap map or BitmapHDR map from Max.
the bad effect of this miss, is that you can't see the update of your HDRI.
Even if browse again and select it again .
I've finally find a way to force the update of this map with VrayHdri Map. i'm changing the Gamma value parameter of the vrayhdri map and the map is updated.
It's only 2 left mouse button work , but it could be better if you add a reload button.
By this way, i modify my map in Hdrlightstudio , i save it ( or replace it ) , and i push reload in the vrayhdri map parameters to see the changes.
best regards
best regards
