Batch Render and exr support
  • Batch Render and exr support
    I've just use RT for testing purpose (here and here) and I'd like to aks for features :
    . EXR support when using "make preview animation..."
    . Batch Rendering with probably the same workflow than VRay Prod
    . Render Elements support : probably not at the same time but some basics passes like AO/Zdepth/etc...
    Thanks !
    Shop | Work | Blog
    You can assign V-Ray RT as production renderer and in that case you can save to whatever file format you want. Also you can use batch rendering.
    Render elements are coming up.
      Can't believe I did'nt try ^^
      Thanks !
      Shop | Work | Blog
