GPU: VrayLight Directional support
    Originally posted by tashko.zashev View Post
    No, not yet.
    Thanks for the update Tashko. I just took a look at the Maya thread are the stochastic flakes in the 3ds Max nightlies too?
    "I have not failed. I've just found 10,000 ways that won't work."
    Thomas A. Edison
      Yes, Stochastic flakes (in RT GPU) is available in the nightly builds for 3DS Max too.
      Tashko Zashev | chaos.com
        I just loaded the latest stable nightie and its not available in GPU for Max.
        Thomas A. Edison
          eyepiz is right. It is available in the dev nightlies only ... It will not get in the stable ones, since it is a major change.
          Best,
          Blago.
          V-Ray fan.
          Looking busy around GPUs ...
          RTX ON
            Thank you for including directionality support in nightly builds!!!
            • #21
              Are the Dev nightly builds available to users or is it just the stable ones?
              Thomas A. Edison
              • #22
                By default it is the stable only ... the dev nightlies are being released every day and are not well tested. Because of that they happen to be broken occasionally (crash, render wrong or slow, etc). It is better to use the stable builds unless there is a reason to experiment with the nightlies .
                Best,
                Blago.
                V-Ray fan.
                RTX ON
                • #23
                  Is this available now? If not, will it be available in 3.5?
                  Edit: Just seen this on the roadmap for 3.5 woohoo!
                  Freelance 3D Generalist
                  www.maxwood.co.uk
                  • #24
                    It is supported in 3.5 beta and will be in the final 3.5 as well.
                    Best,
                    Blago.
                    V-Ray fan.
                    RTX ON
