Is there any way to put the main GPU (used for display) on low priority? So we can still use it for rendering but it doesn't lag like crazy in every operation... Right now i have to switch it off for rendering. Other GPU renderers have this feature, would be nice to have in Vray too.
Low Priority Main GPU
Originally posted by benb32 View PostSuppose you can always try and reduce the ray bundle size - know it's not the same as changing the priority, but it will reduce the lag with the small price of reducing the rendering throughput.
The best thing one can do is to reduce the chunks of work each GPU gets.
We call it "reduce bundle size and rays per pixel", other probably are calling it "lower priority". It is not lower priority however.
Best,
Blago.V-Ray fan.
Looking busy around GPUs ...
RTX ON
Best,
Blago.
Originally posted by Moriah View PostWhat's a good value for those? I just tried bundle size = 32 and rays = 4 and it's still very laggy... I have 3x 980 Ti
We are using all CPU threads to feed those GPUs and probably we need to add option for fewer CPU threads to do that.
Anyway, if you have 3 GPUs, I think it actually might be faster to use only 2 (but fully utilized) for rendering and leave one for monitor, instead of having 3 not-well utilized.
Best,
Blago.V-Ray fan.
RTX ON
Any news on using less priority?
It just feel like such a waste to have something like two Titans just for the RT part, and then maybe a 1070 for the viewport. I know that if I did this and then used them all for RT, the memory availability would be capped at the amount of RAM of the smallest card, but how would the speed of the cards affect this? Would each card compute at its own pace or are they all synchronous?
Originally posted by Nicinus View PostAny news on using less priority?
It just feel like such a waste to have something like two Titans just for the RT part, and then maybe a 1070 for the viewport. I know that if I did this and then used them all for RT, the memory availability would be capped at the amount of RAM of the smallest card, but how would the speed of the cards affect this? Would each card compute at its own pace or are they all synchronous?Last edited by Raph4; 06-03-2017, 06:57 AM.
Great!
But how would this work if I for example have a 780 and then adds a Titan X to it. Would the 780 somehow determine maximum speed in the same the way it would limit how much memory is accessible if I want to use both cards in low priority mode?
Otherwise - when Low Thread Priority option is "on" we utilize the GPUs with attached displays less and we try to feed the other one as usual. The problems we get are that sometimes this can actually slow down the whole render process, because of some internal waits that occur, so we will see.
Best,
Blago.V-Ray fan.
RTX ON
I hope you can get it to work, there is something inherently frustrating with not being able to use all your fire power not to mention the irony of having for example dual 1080s or Titans and then driving all your viewport graphics with a 780. :/
I was just about to post regarding this! Happy to see it will be coming soon, I'm running a 980 Ti but it's a struggle to use for look dev because of the UI sluggishness.
Might this be available in 3.5?Last edited by maxwood; 08-12-2016, 03:04 AM.Freelance 3D Generalist
www.maxwood.co.uk
Originally posted by maxwood View PostI was just about to post regarding this! Happy to see it will be coming soon, I'm running a 980 Ti but it's a struggle to use for look dev because of the UI sluggishness.
Best,
Blago.V-Ray fan.
RTX ON
Originally posted by savage309 View PostIt is in the 3.5 Beta now, will be in the 3.5 final as well. Feedback will be helpful.
Best,
Blago."I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
