Bump map causes harsh cutoff line
  • Bump map causes harsh cutoff line
    Hey Ivaylo,
    I have a quick question here: We commonly use the VrayScannedMtl in a BumpMtl to give certain scans a different appearance. However, we do get very harsh cutoff lines (shadow terminator is the correct term I believe). A simple VrMtl with the same bump map looks better. I know there were some fixes made to one of the last releases in that regards, can this be done to the VrayScannedMtl as well?
    VrMtl in a BumpMtl
    Regards
    Oliver
    You mean the shadow terminator is sharp only with bumped material, but if the same "naked" material is placed over a curved geometry the terminator is OK?
    Sounds strange, i will investigate it
    ______________________________________________
    VRScans developer
      Yes, exactly. The shadow terminator in the ScannedMtl alone looks fine. The harsh cutoff only show up when it is bumped via BumpMtl. If you need a scene, tell me.
        Can't reproduce the problem, could you attach a scene (if possible, max2017 format)?
        Few months ago some issues related to VRayBumpMtl were fixed, it may be related to this fix, so it's possible that since the end of october the bug is resolved.
        VRScans developer
          Scene file is sent to you, Ivaylo.
          Simply set the bump amount to 0 and the strong terminator should go away.
            hmmm, can't find the mail with the scene, i suppose you sent it to my mail, not to support or something like that?
            VRScans developer
              No, directly to your mail.
              I just sent it again.
                Hello.....?
                  well, modern problems, the mail was in the spam (not clear why), the spam folder was invisible.... anyway, the scene is here, thanks
                  VRScans developer
                    Maybe the filter has an issue with our links to the FTP server.
                      Are you able to reproduce the issue?
                        No, it renders black, and there is message "The Object XRef file: "...\Int_Sportback_v01.max" can not be found". Is it the object that is rendered?
                        VRScans developer
                          No. The Xref message is because of some helper object in the scene. You need to have bercon noise installed, but it happens with any map inside the BumpMtl.
                            There are no other messages for missing components. Btw, i can't see the geometry in the viewport, would you tell me the name of the object, to check in the object list?
                            VRScans developer
                            • #15
                              Indeed, the missing Xref was the cause. I sent a new file to you via Mail.
