Using a bitmap for Paint color doesn't work on GPU
  • Using a bitmap for Paint color doesn't work on GPU
    Hello,
    I'm trying to use a bitmap for Paint color on some scans with the RTX engine, nothing happens. It seems to be working fine on CPU though
    This happens with all scans, is this not supported on GPU?
    I'm pretty sure this used to work in the past.
    GPU RTX ,
    CPU engine,
    Maya 2022
    vray_adv_51030_maya2022_x64_30892_install
    Windows 10 21H1
    Nvidia Studio drivers 471.11
    RTX 3090
    Scene here,
    https://drive.google.com/file/d/1HeN...on88zDvDB/view
    Used Scanned file, fabric_0014.vrscan
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
    As i see in the code, it's not supported,are you sure that it was working at some point?
    ______________________________________________
    VRScans developer
      Thanks for the reply, I mostly use the GPU engine in Vray.. and I think I have used this in the past
      Maybe I used it with CPU in the past I will need to check some of the old files
      The paint color for Fabrics and leather is key honestly (with a bitmap)
      This is what I'm working on now,
      I need a bitmap for the paint color on the carpet to get a bit of variation (to match the older look) , this scan does a very good job or else I will need to build this material from scratch with displacement
      Is it possible to have this work on GPU ?
      I also realized you guys added some new scans this year, is there a way to download the entire library to use it locally? or do I need to download them one by one?
      Thanks!
      Muhammed Hamed
      chaos.com
        I'm afraid the map option can't be added easyand fast to the GPU implementation, but you can try combination of blend material +vrscans to add some variations, may be this is even the better option. The paint feature is designed to be used with plaincolor materials (like leather, carpaints etc) , and the naturalcolor of the material is replaced entirely, not just modified (perhaps you mean the filter color option?).
        VRScans developer
          I use Paint Color with leather, wood, fabrics..etc and Filter Color is more for metals
          For this Carpet it is gonna be a map for Paint Color, variation in brightness and saturation. I will do a render on CPU to show you the effect
          Using a blend material could achieve the same I think, it will take time..Paint color should be easier
          I think I will live with this for now
          And about this part
          Do I need to downlaod the scans one by one?
          Thanks!
          Muhammed Hamed
          chaos.com
            As i know there is no option, because the size is huge , you have to browse and download what you need.
            VRScans developer
              Some update: the whole library is uploaded to FTP server and access is given on demand, write to vrscans@chaosgroup.com
              VRScans developer
                Great news, thank you!
                Plenty of people would find this very helpful btw
                Muhammed Hamed
                chaos.com
