The 3dSmax resource collector doesn't seem to pick correctly the vrscans
  • The 3dSmax resource collector doesn't seem to pick correctly the vrscans
    Hi!
    I'm not sure the problem is from the software or from the plugin.
    I was testing the vrscans at both my work and home. But there is no way the resource collector would link the vrscans. so every time i open the file i must relink the materials. With three or four materials i have no problem but i might have a bad time if i had 30 on the scene.
    It was the same behavor in MAX 2015 and in 2017.
    it's not urgent, but it's a thing.
    Thank you in advance.
    can you describe step by step how to reproduce the problem?
    ______________________________________________
    VRScans developer
      Sure. Thank you for the quick answer.
      Let's say at work i load three materials from vrscans. I also load a hdri for the environment and at least a couple of 4k textures
      When it comes the time to go home i try to use either the "ARCHIVE" command in the SAVE AS menu or the resource collector that is in the utilities panel.
      Both perform well the archives colletion but when i decompress the ZIP file and open the MAX file in my computer the materials on the Material editor and check if everything is ok i discover that the vrscans show the "invalid material" message and i have to re link everything again so it can work.
      In short. The materials are packed correctly but the material editor doesn't read the real location of the vrscans when i unpack.
      Best regards.
      Aleks
        thanks, this is strange because i'm almost sure i used archive to transfer scenes and it was working, will try it again
        VRScans developer
