Hi folks,
Max 2016 SP1, Nitrous, windows 8.1 pro, 1.3RC1.
I’m just adding here as I come across them but they’re all basically related to one thing - IR restarting:
Selecting the camera being rendered causes IR to restart
Clicking on the phys camera underneath a coronacameramod causes IR restart (and visa versa)
Move mouse over any coronamaterial in material editor = popup tooltip = IR restarts
Also seems to apply to some other tooltips elsewhere in UI
Simply click on any other material in the editor and the IR restarts (not every time, only some times)
Close material editor and re-open it - IR restarts.
IR seems to get jammed a lot, with no visual update, but it’s rendering away in the background, then dumps an update in one go to the viewport/floating window.
Select a light, IR restarts. Deselect light, IR restarts. No changes happened to the scene.
Keep cursor off 3ds max UI, IR rendering is fine. Move cursor back over the UI anywhere and IR restarts.
Maybe related to the one above - launch IR window, keep cursor over max UI. No update happening to IR. Move cursor off Max UI and bam - IR updates and image appears.
These last two, plus the one about tooltips, are probably the most obvious and problematic issues.
