2.5d Displacement Playground!
In the v5 Daily builds starting from 2019-09-30 we are proud to release the new 2.5d displacement!
It is much more memory efficient than the original displacement, allowing much finer displacement (smaller screen/world size) while using less memory.
Enabled by default for new scenes, but disabled for older scenes for backwards compatibility.
It can be enabled by a new checkbox in performance tab of render settings.
The daily build is available to all license holders. Info and download:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000570015
Any tests are welcome, and we are super interested in your feedback.
New vs old. Render settings: 1px for new displacement and 3px for old displacement. Old displacement consumed less memory and looks better despite vastly larger screen size. Artifacts in new displacement mode, is very obvious. Floor displacement is exaggerated on purpose. Also there’s quite noticeable change in lighting/shading (?) on the wall’s corner. Might be because wall material also has displacement, albeit very subtle.
Edit: Corona uploader doesn’t want to work, so if you need the scene, let me know and i provide the link though PM.
I just tried the uploader and it seems to be working for me. Could you try again?
We are aware of some issues with artifacts and and memory consumption, these will be addressed in the upcoming dailies.
Cheers,
Rowan
I tried, but it just doesn’t work. I will write you PM with the link to the file.
Yes, we’ll be releasing displacement fixes and optimizations in next daily build. In some extreme cases the memory consumption is now 10x lower than in last daily.
Hi Romullus,
Just an update, I have rendered your scene with the upcoming daily build and I think the results are much better with pixel screen size set to 1.
Please see the attached comparer: Romullus displacement scene | Corona Renderer
Note, it’s obvious that the displacement on the mirror is now different. However it looks more correct to me now.
Thanks,
Rowan
Great to hear that! Looking forward to new build.
P.S. mirror material doesn’t have displacement - it was just misplaced geometry, which i moved to correct position before sending the scene.
The daily build with the artifact fixes & additional optimizations has just been received, so enjoy :smiley:
It’s weekend, why are there no new renders here? :wink:
Just kidding of course, but we are super interested in your experience with the new build.
Loosing optix denoiser holds me back from dailies and perhaps new version.
There’s a big discrepancy between two displacement methods in how they treat mapping channels. If 2nd or higher mapping channel of an object is empty and there’s a displacement map in the material, which uses that channel, then new displacement ignores that map and do not displace geometry (which seems logical), but the old displacement for some reason is copying mapping from the first channel and pastes it in the empty channel (which seems odd).
I can no longer reproduce artifacts, which is nice, but displaced geometry still has strange shading on shallow angles with new displacement. I wonder if it’s a limitation of 2.5D displacement, or maybe things can be improved here?
One more test. New displacement @ 1px VS old @ 3px VS old @ 3px with disabled autobump. In my opinion, old displacement with enabled autobump, looks the best.
Hi Romullus,
Is there any chance you can send over this scene?
Thanks,
Rowan
Sure.
1570453279_displacement-test.7z
Thanks!
Regarding the issue with the mapping channels, I think this has been reported: https://forum.corona-renderer.com/ Corona Renderer 5 for 3ds Max - Daily Builds Discussion #msg152049 Can you confirm it’s the same issue?
Rowan
Negative. The report you’ve linked, is about displacement only working in base layer of layered material. I’m talking about mapping channels. They are independant from materials. Let me know if you want more detailed report with examples and max scene.
Ah okay. In that case then yes, a more detailed report and scene would be really helpful.
Thank you
I’ve created proper report in bug reporting board.
Ohh, 2.5D Displacement does not gradually replace Displace with Normal/Bump at a distance?
That would be a hard blow to usability. Or is that just a bug?
Autobump option is greyed out when 2.5D displacement is chosen. I wouldn’t say it’s a deal breaker, because autobump works very well in some instances (like in my last example), but quite often it fails miserably and much better results are obtained with autobump being turned off. Anyway, it might be just temporarily and maybe devs will make autobump to work with new displacement too.
