2010 installer gives error and won't install
I just downloaded max 2010 32bit installer. I have been using max2008 and vray. Installer gives error and won’t install right. It just gives an error message but not a reason for it. I am using windows 7. 2010 64bit installer won’t even install cause f-secure says it’s dangerous file :slight_smile: Anyone else got this problem?
What kind of error do you get from the installer?
I guess I am not so used to windows 7 yet. I had to run the setup file using run as administrator command. Not it works just fine. Thx for the reply though.
