hi guys. i am about to get my new system and i looking for upgrading my primary monitor. now i have 24 dell ultrasharp ips 60hz and a secondary 19 inch viewsonic.
I am having hard time decide between the 27 inch ips 1440P
gigabyte 27 aorus ad27qd
and the 32 inch VA panel 32GK850G-B.
some say 27 is the perfect spot rez for 1440P
but some say with 32 inch i will have an easier seeing things …
i am 35 years old… my eyes are not what they used to be so having a bigger monitor could help me reduce the effort for my eyes?
the usage will be 8 hours 3dsmax a day and light gaming at nights.
thank you for your help.
i went back to 2 x 25" delll ultrasharps for for home studio and was shocked at the step down from dual 30" at work…getting used to it but given the choice again I would put more money in to get the larger models…space permitting.
ok so you fell that the pixel density of the 32 wont make the text and 3dsmax viewport looks blury? some said that with 27 1440P the text look right but at 32 1440P rez i can see the pixels
27 inches is the perfect size for 1440P, 43 inches is perfect for 4k
in your case going up to 32 inches should be as good really, it is all about personal preference
you can use upscaling if you want bigger text maybe. but you will be fine
But why do you want a very high refresh rate? do you plan on gaming on them?
I would go for the IPS 27 inches panel btw, better colors and viewing angle..
But if you don’t do gaming, don’t buy high refresh rate monitors.. part of what you pay is dedicated to this feature, so you better spend the same money on something that is better for working with colors
