We are encountering long files opening, takes 3-4 minutes to open 80 mb file (compressed), which is painfull when using DR (3-4 min parsing). Anyone else has this problem? We have 10gb network, so assets loading isn`t it.
Thanks!
Edit: Charlie has it all written down, seems to be a major problem, would be great if everyone with the problem to join the discussion:
So could be good to have a summary post can anyone prove/disprove/add to any of the following;
Factors the issue is not directly related too. - ie the issue still occurs with a change/removal of said items
Server OS - Qnap,FreeNAS,Synology all tested
Antivirus Software - Disabled + tested on Multiple
Client OS - Windows7/Windows 10 Testes
3DS MAX Service Packs - SP3 and SP4 Tested
XREFS
FTH
Factors that seem to resolve the issue. - ie The issue has not come about post action
Copying a file + assets locally.
Removing all maps & assets.
Possible Further Tests
Server Packs Pre SP3 - Tested, didn`t fix the problem
Removing all Plugins/Scripts …
Testing with a different version of MAX
Retimers https://forums.autodesk.com/t5/3ds-max-forum/max-files-take-ages-to-open/m-p/5521825#M99827
Check ping with license server. When 3ds max starts, it is not just max that checks license, many plugins also checks license.
Observations - All on the same scene file
When opening the file whilst watching it load into RAM a sudden slow/freeze occurs
After opening this file opening a second copy of 3DS Max at the same time and trying to open the file again (whilst the first copy is still trying to load almost always loads perfectly
Network not stressed at time of file opening
I had a problem with xrefs, when merging everything into one file, It took 3 minutes less to open the file. Did you try to merge everything into a new file and if possible delete all the cad plans?
does every 80mb scenes always takes 3-4minutes?
my friend has 10gb network and experienced this too. his problem was the bottleneck transfer data in RAID disk read/write .. i don’t have deeper knowledge in networking nor PC hardwares, so i cant explains the details.
I had FTH disabled and this issue is still occurring.
Autodesk Tech Support’s Response Basically asked them why 3DS Max takes so long/gets stuck opening files 2016 SP3 in a network environment – Note taking a file + Assets locally fixes any problems opening the file
Second Note - Removing all texture files seemed to stop this happening hence promoting a more specific response
I have heard back from one of our Principal Engineers in regards to this issue, and he mentioned that this sounds like a possible problem with the FileWatch system in 3ds Max.
For instance, when you load a scene file, Max will load the scene file and then immediately close it. So with someone else opening that same file, it shouldn’t have any effect at all, at least in terms of the scene file itself. But if the file has bitmap texture maps, then a FileWatch is placed on the bitmap files. So in this case, you will end up with multiple FileWatches on the files from different 3ds Max sessions. That shouldn’t cause a huge problem, but sounds like it may be in this case.
So let’s try turning off ‘Reload textures on change’ option in the Max Preferences and see it that helps. =]
In regards to Kaspersky, I am not sure of any know issue at this time…however, I will mention that in previous years (when I was working in Production animation) we had Kaspersky as our anti-virus software and Max would not run properly with it enabled. – Again, this was a few years ago but it may be worth disabling it just for some testing to find out if that is still the case.
I can confirm disabling FTH doesnt work. Did the "Reload textures on change" help? What is that? edit: That doesnt help either. Something is slowing dow/disabling access to maps that are on the network, but what I have no idea. Firewalll and antivirus disabled, still nothing.
Same results here, all suggestions from Autodesk have had no effect however the support team did kindly let me know that ‘3DS Max was not designed to run scenes across a network with multiple users accessing the files’ …
jaw drop
… It’s got to be something case specific though otherwise surely more people would be highlighting this problem..
XREFS
FTH
Here is something that could work, this guy says its probably missing network paths issue, not sure if it is:
Short answer (for those TL;DR guys out there):
Non existing network paths is the problem here. Solution is to re-link the assets by a script before opening a .max file.
Here the proper answer:
I can’t tell exactly who is the culprit here, if it’s 3dsmax, Windows, network card/drivers or the network itself, but the fact is that once you load a texture into your max file from a network you end up with 3dsmax checking that network path every time you open the scene. Which is correct, right? Unfortunately this becomes a problem when that network path no longer exists. For some reason it takes a long time for 3rdsmax/windows/network card to figure out that the network path doesn’t exist anymore and if you have a scene file with dozens of textures then it can take 10 or more minutes to open it. I observes this varries on different setups and networks.
Anyway, the solution that I found is to re-link the network paths of assets (textures, xrefs, etc.) in the scene file before opening it by using Maxscript. Just search for “getMAXFileAssetMetadata” and “setMAXFileAssetMetadata”. I made a simple script using those functions which takes a .max file of your choosing, looks for any assets within the file with network paths and re-links those paths to local space. It’s quite simple and doesn’t allow much of customization (let alone error checking) so I don’t dare to upload it here but if anybody’s interested feel free to PM me or write me an e-mail and I’ll send you the script. I use it successfuly on old files and they all load very quickly now.
