https://area.autodesk.com/blogs/the-3ds-max-blog/3ds-max-20202-feature-updates/
New Sketchup importer
Viewport update
Chamfer update
Performance update
and many fixes!
Viewport update
Chamfer update
Performance update
and many fixes!
Tried out the new sketchup importer. Itâs working great!
Couple more features would be nice, but it works much better now
We donât know details about it, but we will certainly ask.
Still wonât use it, because that stupid double-click issue is not fixed yet. Again, since 3 years!
Is there any reason to go from 2019? On 2019 I crash 1/2 dozen times a week, for no real reason and a lot of not responding. Is it better in 2020?
That is good to hear. We were talking about it about 6 months ago and AD said that they didnât know there was an issue importing SU models. I am glad they listened to us.
You should ask Vlado to convert UI to Qt.
Arnold and ART doesnât have the issue.
Itâs on the âto doâ list, but there always seem to be more pressing issues⌠Also, the problem is present in the Common tab as well, which is there for Arnold and ART and has this problem too. I asked Autodesk to convert it to Qt so that we can see how itâs done. There is nothing so far ![]()
Hehe thats âCommonâ problem I guess.
BTW, Zap said you can check âHLSL fragmentâ
Ok, thanks for the pointer ![]()
Since the update, max crashes every time I open the Render settings window⌠Anyone else experiencing this?
This problem is present in some other windows which have nothing to do with V-Ray.
Literally just now updated and it appears to be fine. Just checked again but no issues so far. All I have is a clean Win 10 install with Max/Forest/Vray Next so maybe itâs some weird other plugin conflict.
This happens only legacy Tab UI Which is all rendererâs UI and Common and Render Element tab.
ART and Arnold UI have been Qt from the beginng.
Yes, max team need to take care Common and Render Element tab.
But, each renderer dev also need to convert UI to Qt eventually.
@AlexP Yes, I have the same issue with Max vaporizing when opening render settings. This didnât happen with Max 2020.1.
Iâve been using 2020 since May and have had disappointing reliability. Overall performance seems fine, but stability is not so good. I even have fresh install of Win10 Pro and Max 2020.2 and still have stability issues with Max.
The updated SketchUp importer is great in respect to being able to import current versions of SketchUp files, but not happy at all that Iâve lost the ability to select a specific folder for the imported SketchUp textures. And as far as I can tell linework is not imported. A lot of times I have imported Acad files in the SketchUp scene that Iâd like to be imported with the rest of the geometry. One step forward, two steps back.
Iâm going to park 2020 for the time being and roll back to 2018. Which for me was more stable than 2019 and 2020. I so love paying subscription fees for beta software.
That isnât encouraging. I just had a ZOOM meeting and MAX froze three times and I had to crash it and relaunch each time to get through the meeting. It is embarrassing as if I am using some freeware or something. I was hoping 2020 was more stable. It is one thing wasting my time with the ânot respondingâ garbage, but when it is in front of clients, that is another thing.
Any hint about when it is unstable? certain task? Any repro steps?
For me, that is the frustrating part. I can be working along, picking things and everything is fine. I can pick the same thing again and MAX will go into ânot respondingâ. I can be panning and zooming, without a problem and then all of a sudden, ânot respondingâ. I was encouraged awhile back when an AD guy said that the ânot respondingâ is the most mentioned issue with MAX. I was encouraged because at least they acknowledged it and I was hoping they would fix it.
