3dsmax crashing all the time
Hi guys, 3dsmax is crashing all the time, with no aparent reason.. here is the mini dump if someone can help would be awesome..
dumpdata.zip (1.44 MB)
try this one
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Resetting-3ds-Max-3ds-Max-Design.html
Which versions of Max and Corona are you using?
Could you also provide some steps for us to reproduce the crash?
My signiture contains a link to the information we ask for.
Thanks,
Rowan
Corana Renderer 3.2
It crashes both 2018 and 2020max.
We got 4 render box machines with same configuration. All of them renders ~1.78 GB / 33 Frame / 6-7 hours and then crashes suddenly and max splash error screen.
All other machines stops render and crash consecutively.
We have to start render every 6-7 hour again and again. Render file is ~5GB with 7000 frames.
Would you be able to provide your scene? Could you also tell me if you are using DR or some render manager, and/or any thrid party plugins?
Thanks,
Rowan
Unfortunately due to credit policy cant provide scene. But I tested scene different PC apart from 4 render boxes. It didn’t crash after 43hours runtime and I stop it manually. Therefore I think scene is not the problem.
We dont use render manager, and/or any thrid party plugins.
Regards
Are you using Win 10? Do you have all updates installed? It seems like the newest update fixes some random issues for some users.
Finally I manage to catch error message from Corona before Max Crash.
How can i fix Ram Problem?
===== Warning(33) =====
System is running low on RAM. You may experience excessive parsing times and/or crashes. You will probably have to simplify the scene.
128,2 GB of virtualized* RAM used by Corona + 3ds Max
134 GB of virtualized* RAM used by all running applications
127,7 GB of physical RAM installed on system
146,7 GB of virtualized* RAM provided by OS
  • virtualized RAM means physical RAM + swap file on HDD/SSD
Corona RAM usage breakdown:
783,5 MB used by render elements
17,5 GB used by geometry
192 MB used by textures (CoronaBitmap only)
There’s a “Learn More” link in that error message which goes to https://coronarenderer.freshdesk.com/support/solutions/articles/5000675854-system-is-running-low-on-ram-you-may-experience-excessive-parsing-times-and-or-crashes-you-will-pro
The most obvious answers are - add more RAM, or simplify the scene :smiley: Other things that may make just enough difference, depending how far out of RAM you are, are given on that page.
