A different RenderElement set for every State set of 3dsMax cannot be created.
The following errors are displayed.
1 states have encountered errors and have been disabled to allow you to continue working. Please report this to Autodesk by sending us the following text:
State type: Autodesk.Max.StateSets.Entities.StateSets.Rendering.RenderElement+Parameter
Error: System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
at Autodesk.Max.Wrappers.Value.get_ToBool()
at Autodesk.Max.StateSets.Entities.StateSets.Rendering.RenderElement.Parameter.get_FileName()
at Autodesk.Max.StateSets.Entities.StateSets.Rendering.RenderElement.Parameter.GetParameterValue(Properties property)
at Autodesk.Max.StateSets.Entities.StateSets.Parameter`1.EndRecording()
at Autodesk.Max.StateSets.Entities.StateSets.State.EndRecording(IState state)
It is not supporting?
