Does anyone know how to create the white frosted glass in Vray that only let 50% of light transmit? We are doing a lighting study for backlighting a frosted glass but couldn’t get the right glass material. Please let me know if anyone has any thoughts. Thank you!
I feel like I’m missing something, because it sounds like all you need to do is set the transparency to 50%?
And make the Diffuse white instead of black. And the color of the Transparency is also to a grey not white. Check it out with tests and see what is the setting you need, but tweak those three parameters and you should get the material you are looking for.
