8800GTS + 3DS Max 2008 + Vista 64 :(
Hi all
I’m experiencing some serious lack of performance in the viewport with the above combination. I’m running the latest Nvidia drivers. Has anyone got a similar setup? I’m considering going back to WinXp…
Thanks for all suggestions and help.
I have the exact same setup… What sort of problems are you encountering?
basically the viewport in max is super sluggish. Even a light scene, say around 100K polys will crawl along. Compared to an older machine with a 6600GT , the 8800GTS is alot slower.
Are you using scatter objects by any chance?
I’ve noticed the viewport in Vista to be considerably slower than in XP. It can handle up to a certain amount of polys before it starts to freeze.
I have a similar setup (GTX - rest same) and encountered massive performance problems with Vista 64 even with a high-end-system (3.2 Ghz Quad and 8 GB RAM) in Terms of Viewport - Performance.
My temporary workaround was to use DirectX and let the adaptive optimization of MAX2008 do its job - anyhow - Vista64 sucks - currently.
