A so stupid question :-)
embarrassing for me :rolleyes: I can’t figure out what the Capture Resolution option “Window” means or does
It means that the capturings are done exactly in the window (viewport) resolution :slight_smile: E.g. stretch window to 1000x10px and screenshot will be captured in that resolution.
thanks a lot for your so fast help :slight_smile: do you mean SkUps´s viewport or Enscapes Render viewport? and how could it be possible to adjust the viewport window to any exact desired sice? I tested this but despite the used setting “Window” Enscape again reinvents its own sice preferences which are so completely useless …
As you can see, I don’t comprehend anything 8o :slight_smile:
Enscape window vieport size.
This option is designed to make a capture with the resolution you currently have in your Enscape window - what you see is what you get (in terms of resolution). If you need a specific screenshot resolution, you may want use the “Custom” option and input whatever you want*.
    • there are software and hardware limitations though :wink:
Thamks again :slight_smile:
hmm - this entire camera- and resolution thing is still somehow “unfinished” and unclear … :wink:
