a little problem with the aa:
my problem: the central jouint of the window disappears on the image (originalk in 1600x1200):
My setting are Adaptive subdivision, Min rate 1, Max rate 3, Trehold 0.1, Multipass
What’s wrong on my setting ??
Vince
natty
2
hi
what are your min max gi settings ?
natty
4
mmmm … no probs there ..
perhaps increase your light subdivs, they do look a little low.
or cheat and increase the gap a little
your treshold is very high make it 0.03 or even less if you still have trouble. (I mean if you havent typed wrong > 0.1)
natty
6
that is the standard high settings losbellos
I often use simple two-level set to: Min rate 2, Max rate 6, Treshold 0.08, multipass
TJE
8
Or the quick one I usually do: Photoshop copy/paste…
dist thresh could also be chaned as well. try 0.3
I always use .05 for the AA threshold. It will probably solve your problem and doesn’t slow it down to much.
I agree, turn your Threshold to 0,05. I’ve got the same problem as you and solved with more quality setting…you know…times goes up!
Valerio
